perry-westphal avatar image
perry-westphal asked
No modbus unit ID - carlo gavazzi gridmeter
Carlo gavazzi ET340 is connected but there is no modbus ID.
I see meter firmware version 3.
Every 5 minutes meter connects and disconnects.
I already tried a new color control.
I already reconnected the 3 cables that come from the USB.
Anyone any tips?
Energy Meter
markus avatar image
markus answered ·
Your meter shouldn't disconnect.
As you already have tried a new CCGX, the problem could be the meter itself, the cable from the dongle to the meter, or the USB to serial adapter.
I would try to connect the meter to the Usb converter without extension cable and see if that works, if not, change the Usb to serial converter to a new one, if that doesn't help, make an RMA request for the meter.
BR
