jayjay avatar image
jayjay asked
Low voltage on the master inverter only
We installed three Quattro 10kW for a three phase system with lithium battery storage. The master inverter's low battery light is on, while on the other two inverters the light is off. Also, on the color control as well as on the battery's display, the battery voltage is 50V (70% SOC).
Can anyone advise the reason for this warning?
Lithium Batteryquattro 10kvalow battery warning
marekp avatar image
marekp answered ·
@jayjay
Did you check the fuse?
tnt369 avatar image
tnt369 answered ·
In a three phase system only the master shows the status by LED. The other two units are slaves and don't show their status. Check the DC voltage and connection to all three units.
marekp avatar image
marekp answered ·
@tnt369
In the 3 phase system there is no one master. All three units are masters for respective phases.
Master and slave exists in the parallel connections.
Battery Compatibility
