corbijn avatar image
corbijn asked
Only using SmartSolar 100/20 for charging LiFePo4 12v 100AH battery
Hi there,
I have a SmartSolar 100/20 which I use to charge a LiFePo4 12v 100AH battery. I used to have a GEL battery and would often use the 240v 15a charger due to the length of time the Solar charger would take.
Given the speed that LiFePo4 batteries can charge I am thinking, I don't need a 240v charger. I am normally only away for a weekend camping and if there is no sun my minimal use will leave with me with enough capacity.
Am I missing something? Are there any flaws in my logic?
Thanks in advance.
MPPT ControllersLithium Battery
seb71 avatar image
seb71 answered ·
So the battery lasts you over the weekend even without charging and you ask if it is enough time to re-charge over the week from the Sun?
If yes, it should work, if you have enough PV power and at least some sun (so the vehicle is not kept in a garage or in shadow of a building for instance).
At maximum your 100/20 charger can charge the battery with 20A (if you have enough PV and sunlight). That means maximum 20Ah in an hour.
corbijn answered ·
Thanks - I suppose I was wondering if there were any oddities about the charging process related to Solar - but maybe I am just displaying my newbie mindset :) The 240v chargers are just so consistent - but that must not effect battery performance.
Just make sure you set the solar charger correctly for LiFePO4. Start from the default LiFePO4 profile and tweak it for your battery.
corbijn avatar image corbijn seb71 commented ·
Yeah thanks :) I had astarted a question on that very topic. I'm still waiting to hear back from my manufacturer though!
