Float set to 13.6v
Smart shunt set to 14.1V
Float set to 13.6v
I figured it out and it’s entirely my fault! It was the VE. Bus Smart dongle. As soon as I unplugged the dongle it went into bulk charge. I think it’s because I took a shortcut and attached the positive and negative terminals of the dongle directly to the open bolts on the DC terminals on the multiplus instead of to the battery or bus bar and either it was reading the voltage that it was sending to maintain the coach DC system, or not taking into account resistance of path to the batteries. Anyway, it’s now floating at 100% correctly. I thought I had it set to read it’s settings from the smart shunt, but apparently it wasn’t or was overriding. Thanks for all the help!
SmartShunt Installation Manual
SmartShunt Quick Installation Guide
45 People are following this question.
