Bill avatar image
Bill asked
Comparing BMV 700-702-712
Does anyone know if there is a comparison paper or chart for the BMV lineup? After getting the Raspberry Pi working with my current Victron Controllers I am considering switching from a Bogart Trimetric to the BMV to have that info included in VRM too. I guess hearing that should make Victron happy...
-Bill
VRMBMV Battery MonitorVenus OSRaspberry Pi
osaether avatar image
osaether answered ·
BMV-712 have Bluetooth
BMV-712 draws much less current than the other two: <1mA vs <4mA
BMV-712 have a slightly lower maximum input voltage than the other two: 70V vs 95V
mvader (Victron Energy) avatar image mvader (Victron Energy) ♦♦ commented ·
Thats it indeed; besides drawing less current by itself; there is the bistable relay; as pointed out by @Boekel.
boekel avatar image
boekel answered ·
There is this:
https://www.victronenergy.com/upload/documents/Datasheet-BMV-700-series-EN.pdf
https://www.victronenergy.com/upload/documents/Datasheet-BMV-712-Smart-EN.pdf
Usually for me the 700 is enough, but if you want temperature or midpoint / second battery voltage then one of the higher numbers are useful.
Bill avatar image
Bill answered ·
Thanks I had seen those pdf's. I could see no difference between the 702 and the 712. I am assuming there is something as they have different costs. Does the 712 only add internal Bluetooth? Anything else? Thanks Again, Bill
boekel avatar image boekel ♦ commented ·
yes, as far as I know it's the Bluetooth, plus the 712 has a bi-stable relay, so it draws less power when relay is active.
(there might be other things but I don't remember, overall current draw of 712 is also lower)
Bill avatar image
Bill answered ·
Thanks! There is one other thing that the doc's seem to imply that I am wondering if I am getting it straight. The way they word it, the 702 & 712 can only do one of these two options. They can either monitor another battery, such as chassis OR they can monitor temperature but not both. Is that correct? I would like to do both the Chassis battery voltage info and the house battery temperature info sharing/monitoring,
I own a SBS, but I am reading that once a BMV is in play the SBS won't work as only the BMV can provide that to the controllers once that is on the system.
Let me know -Bill
