walter-widmore avatar image
walter-widmore asked
Multiplus connect up to 3 VE.Bus devices
Hi all,
I have a few questions about using the VE.Bus Smart dongle.
I have the following devices:
- MultiPlus 24/5000/120-100
- VE.Bus Smart dongle
- Victron Digital Multi Control 200/200A
- Cerbo GX
(The last 2 devices I basically got for free in a deal at my local store which is why I'm questioning if I can combine them both.)
Currently the MultiPlus is connected to the Cerbo an the Digital multi control so both VE. Bus ports are used. My questions are:
1) Can I connect the Smart dongle to the Multiplus as well using a splitter?
2) Or can I connect the Smart dongle directly into the Cerbo?
3) Is there any benefit of using the Smart dongle and how can I check if it is being used? I disconnected the digital multi control and connected the smart dongle and honestly I'm just not sure what it does apart from me beging able to see the battery temperature (which I can already do using the (non Victron) BMS I use.
Any reply is appreciated. Many thanks.
multiplus ve.busVE.Bus Smart DongleDigital Multi Control
Alexandra avatar image
Alexandra answered ·
@walter_widmore
The ve bus smart dongle goes into secondary mode if plugged in at the same time as other gx and control devices on the ve bus.
In that mode it does through software what the DMControl does that is i put current control and checking what dtate you are in. So it is really up to you how you want to use it.
