the-doon avatar image
the-doon asked
VE.Bus Bluetooth Smart Dongle switching glitch
Hi all, I’m having an issue where the 2 VE.Bus Smart Dongles I own are intermittently failing to turn the Multiplus-II’s on. It shows initiating then fails back to off. Trying it a second time will have success but just wanted to see if anyone else is seeing this issue as it only started happening in the last month or so. This is happening at my home off-grid setup and my setup in my ute. I’m assuming it’s only started happening since the last update to either the dongle or multis.
multiplus ve.busVE.Bus Smart Dongle
