aslanhobbes avatar image
aslanhobbes asked
How to remove AC Input and Loads from VRM Dashboard?
Is there a way to remove these AC Input and AC Loads from the dashboard as I am not using them? I tried to remove them under Remote Console/System Setup/AC Input=Not Available. However, the setting always reverts back to "Unknown". Am I stuck with these two useless widgets in my case? Thanks in advance.
VRMinput currentdashboard display
As far as I know there is no way to hide them.
rubio13 avatar image
rubio13 answered ·
You can change the AC Input from Grid to Generator. My VRM says N/A and AC Loads is showing because I have a grid meter set as grid.
tjenkins avatar image
tjenkins answered ·
I have a similar challenge. I have only a DC solution and would like to remove any reference to AC in VRM.
Is this possible at all?
Below are some screen shots
seb71 avatar image
seb71 answered ·
Workaround:
You can hide VRM Dashboard elements using the uBlock Origin (ad block browser extension), but this workaround is valid per browser. Also I don't know if this is available for phones.
