Is it OK to use the Inverter RS plus a GX interface with BMS-managed batteries like BYD?
Yes, depending on which model battery you choose.
https://www.victronenergy.com/live/battery_compatibility:byd_b-box
Just check the model you want is for offgrid use and correctly sized, as the RS has no grid charger built in.
Inverter RS Product page.
Inverter RS Online Manual.
Inverter RS Datasheet.
41 People are following this question.
