Over the last couple of weeks. My Remote Console via VRM loses connectivity. The Venus is online and reporting and I can use local Lan to connect but it takes a reboot to solve which I can’t do remote. Seemed to start after firmware 2.72.
Hi Scott , I have similar problem, but mine has lost connection from day 1 ( 1 week ago). Is yours connected by Lan or wifi when dropouts occur . I am using wifi .
Hi, I do have the same issue over the last couple of weeks from time to time. In some cases it resolves itself somehow and in other cases it does not and require’s physical access to the device. Super annoying. My device is connected via wifi.
I have noticed on my unit that the Venus Wifi is very week and that remote control can be very slow, I have ended up hard wiring may unit to my router. so maybe hard wire the network port on the venus to a router that has a simcard in it or make sure the hot spot is very close to the venus unit, Also make sure the venus is on the latest 2.72 FW, another option to to use a USB to wifi dongle, this maybe hard as not all usb to wifi units work (sugest you use the victron long range one)
44 People are following this question.
