georgeleonardo avatar image
georgeleonardo asked
Multiplus Compact dead after BMS disconnecting and low battery.
Hello! I had an accident with my system, the negative wire disconnected from my VE.Bus BMS and the battery went very low making the inverter/charger stop working. At least that’s my assumption so far.
The thing is, I can’t make it go back on for nothing. Fuse looks right. AC power is coming in. I’ve even tried to mess up with the dip switch what made it respond at some point with the red light but after connecting it back it stopped responding again. It’s now out of the system, I’m looking for a way to make it respond so I can connect it to my PC. Any thoughts??
Thank you!!
multiplus ve.buslow battery warning
