mvader (Victron Energy) asked
Venus OS v2.71~1 available for testing
UPDATE: v2.71 has been officially released. See blogpost: https://www.victronenergy.com/blog/2021/06/22/venus-os-v2-71/
Good morning!
Lets start with explaining what happened with v2.70. That version has been build, but the release of it was cancelled because an issue was found. And as 2.70 is just a number, and numbers are free, we continue now in v2.71.
That issue is fixed now, it relates to the GX Device failing to reconnect to a Fronius PV Inverter, and perhaps other brands as well, after loosing the connection. And that is also the only change in v2.71~1.
I've copied the full change log below.
Same question as usual with regards to testing and reporting.
The next possible official release date is early next week. Its all taking a bit long now which is a pity, but on the other hand I really prefer releasing solid versions; and if that means delaying, then delaying needs to be done!
Looking forward to your reactions,
Matthijs
What is this about?
This post is intended for all people participating in the Venus OS Beta test program. Read that link for more information about the program.
How to report?
For new issues, add a new answer below. If you see the same as someone else, or know more or an answer for him / her, use the comment feature. Careful: adding a new comment versus adding a new answer are really different things, and you need to look closely to know which button to use for what.
Change log
New in v2.71~1, compared to v2.70~19:
  • Fix regression that under some conditions causes a failure to reconnect to a sunspec PV Inverter. This used to work fine in v2.66, and was a regression introduced during v2.70 development. Thank you @offgridsolutions for reporting this!
Rest of changelog, listing all differences to the last official release which is v2.66.
Tanks:
  • Added the new tank overview page. Screenshot below.
  • Increase the margin above the full tank level to 20%. An example to explain this: instead of showing an error in case the measured current is above 20.5mA, show an error when its over 24mA. In that margin, ie. between the configured full level (20mA in my example) and the error level, it will just clip to 100%. Thank you John M. for reporting this improvement; and in general for your push an getting the tanks full featured such as having configurable alarms and having a good overview for them.
  • Use the same tank name in the alarm notifications, the Device list, the mobile overview as well as the new tank overview page.
  • Add tank level alarms. High level alarm and low level alarm. Note that this is only for tank levels measured via the Venus GX, Cerbo GX or GX Tank analog inputs. No alarm levels are supported for tank levels that come in via NMEA2000.
  • Add fluid type 6, gasoline. To fully match the NMEA2000 supported set of fluid types.
  • Support tank senders that send out levels for multiple tanks using different data instances, such as the Garnet Seelevel N2K product, and the Maretron FPM100. Details also here: https://github.com/victronenergy/venus/issues/551.
User interface & various:
  • Change the name of the battery measurements menu to "Battery Measurements" and add a help text indicating that it is (also) for the MFD HTML5 app. This same info is also used for the VRM Dashboard.
  • Better handle AC-Coupled PV on the output of an Inverter RS by adding AC Frequency item, and by showing negative current and power instead of clipping that to zero.
  • Add the firmware version of a Fronius datamanager on the Device subpage. This is added next to the (already shown) firmware version for the PV Inverter itself.
  • Add EM24 Ethernet meter phase configuration setting
  • Improve the CAN-bus statistics page so it all fits on one screen.
  • Fix issue related to Garmin MFDs and the Victron App, because of which the App wouldn't work on the Garmin when doing a certain sequence of power-ups or reboots (ie Garmin first, or GX device first or other way around).
  • NMEA2000-out: include SOH in the NMEA2000-out function. Note that Victron battery monitors such as the BMV series don't have SOH; this applies only when using a lithium battery with integrated CAN-bus *and* that has SOH.
DVCC / ESS / Mode 3 (External control)
  • Hide the Grid feed-in menu when ESS is set to External control, since they are not relevant in that mode.
  • Disable the PV-limiter when ESS mode is set to External Control. This avoids problems where the PV-limiter aims for a different grid setpoint than that set with ESS mode 3. Instead, the customer is responsible for doing his/her own control.
  • Improvements related to Inverter RS Smart Solar. But not fully finished yet.
Managed (CAN-Bus) batteries & PV Inverters:
  • Recognise REC BMS, and show only supported alarms, ie hide all alarm types for which the REC does not send any status, rather than saying "OK" for those. This (showing only the supported alarms) is a nice feature; for which REC is now the only one that supports it; we're looking forward to seeing the same from other battery manufacturers.
  • Fronius PV monitoring: further improve support for large systems by more intelligently quering the Fronius datamanger. Eliminated unnecessary reconnects, and because of that also reduces CPU load on the GX device. Tested at a site with 6 Fronius ECP PV-inverters, and works well: never disconnects now.
  • Can-bus BMS: support CCL & DCL current limits above 3276A.
Connection to VRM:
  • log a warning to VRM in case one or more modules in a managed (CAN-bus) battery is blocking charge.
  • Add various data for the Inverter RS Smart Solar (AC-out power, energy values, some history data for solar)
  • Show VRM down in case the VRM-data-receival system is down; instead of a vague error that might make people think there is an issue on their side.
  • Change the logging frequency of min/max cell voltage/temperature to fix the gaps in the graphs on VRM.
Modbus-TCP
  • Add registers for total power, power capacity, and power limiting. The power limit register is for external control in ESS mode 3. This is an easier method than controlling the PV-inverter directly through SunSpec. https://github.com/victronenergy/venus/issues/821.
  • Add registers for /Hub4/TargetPowerIsMaxFeedIn and for /Hub4/FixSolarOffsetTo100mV
  • Add registers for Inverter RS Smart
Networking / modem
  • Allow using a GSM modem while connected to a local-only network by not setting a default route if there is no default gateway received from DHCP and/or configured manually.
RaspberryPis
  • Note that installing v2.70 on a rpi can only be done by re-installing. Meaning: burn a v2.70 image to an sdcard, overwriting anything on there. Detailed instructions here. And more details in the discussion going on in the comments.
  • Restored the packages (but to anyone using those, be aware that they are really not maintained, and if there in the way again for us we'll just as lightly as previously decide to take them out again. I'm sorry but that's what it is).
  • Support (some of the) RaspberryPi4s. Some of the means that only some older versions work. Newer do not.
  • Make the Bluetooth work on RaspberryPi3 and RaspberryPi4. The functionality is same as other GX Devices: to setup the network. Which means also that there is nothing else: no monitoring of your Victron system, use Remote Console on LAN, or http://venus.local/app/ instead.
  • Use the complete SD-Card size, rather than a fixed size rootfs, by resizing on boot.
  • Enable the radio on by default, instead of blocking it until unblocked by navigating to the wifi menu page in the gui. This fixes it being impossible to configure the wifi on a raspberrypi via VictronConnect/BLE without first going to said menu via Remote Console. Thank you @Stefanie for reporting - quite some time ago.
More developer / hobbyist:
  • Switch from version Rocko to version Zeus of Open Embedded. A (perhaps too) simplified explanation for this is that its like going from Windows 7 to Windows 8, and then not in what you see, but just in what's running in the background. For those interested, more info [here](https://wiki.yoctoproject.org/wiki/Releases). And yes, Zeus is EOL as well. We'll soon switch over to Dunfell.
  • Linux kernel updated from 4.19 to 5.10 for CCGX, Cerbo GX, GX-Card in MP-II and ES-II products as well as the CANvu GX. And updated from 4.9 to 5.10 for the Venus GX. No change for the raspberrypi, that is still on 4.19.
  • Venus GX: Resize partitions on boot to the "new" large style partitioning. Background: up until the end of 2018, we produced our Venus GX-es with a file system partitioning similar to the CCGX. But the Venus GX has much more flash memory inside. So end of 2018 we changed the production methods. And now with this change, any unit produced before then will also automatically be upgraded to the new (larger) size. This change allows us to add more standard functionality in those older Venus GX-es. And also it makes it easier to install Venus OS Large on a Venus GX produced before end of 2018: its no longer necessary to manually do the repartitioning. Just run v2.70 once, and presto.
  • Fix some management dbus-paths in dbus-pump & dbus-generator-starter, no user visible changes.
  • Update Qt5 to 5.13.
  • Mark menu items that are only visible in debug or other special modes with a color; so thats its clear that its not visible in normal usage.
Known issues:
  • In some cases, one or more tanks don't show when selecting the tank type filter button on the bottom. Tanks can also go missing in the mobile overview, aka the "Boat & motorhome overview", enabled in the Settings -> Display & language menu . This missing tanks issue is being looked into.
  • There seems to be an issue with the RaspberryPi3 WiFi, more details here.
Previous v2.70 beta posts
Ps. the screenshots, first one more Marine oriented, second one more off-grid oriented.
Ps 2. Screenshot of the new low level alarm for a tank. There is a similar page to configure a high level alarm:
Venus OS
Erik Sporns avatar image
Erik Sporns answered ·
Thank you very much for your work! Will there be a venus large build on that (or one of the coming) version?
mvader (Victron Energy) avatar image mvader (Victron Energy) ♦♦ commented ·
Hi Erik, yes for sure.
roger-seibel avatar image
roger-seibel answered ·
Are there missing some values now in the color GX overview like Setpoint etc ?
Hi, I'm not sure what you mean with this @Roger Seibel . In what menu did you have that setting? What was it for?
What GX Device are you using? And perhaps you changed your access level.
roger-seibel avatar image roger-seibel commented ·
I am sorry, i really thought, there was a setpiont value in my main screen of the color control GX. Maybe i mixed it up with my Node-Red-Screen, sorry.
roger-seibel avatar image roger-seibel roger-seibel commented ·
But perhaps there is space for this value ... ;-)
vassilis-bourdakis avatar image
vassilis-bourdakis answered ·
Matthijs,
when could we expect an update in Large?
still running 2.70~3-large-12 on a rpi 3B+ and wouldn't mind getting something more fresh! I do need SignalK though so cannot got small...
BTW, it's been rock solid running 24/7 with no issues whatsoever and just me rebooting it (when changing things on the N2K bus and disrupting it's power) 3-4 times in 6months!
Latest I can see is 2.70~5 large-18 from mid April.
If there's a plan of having something newer released within the following couple of weeks, I can wait, else I'll install this one now as I'm going sailing again in a fortnight.
cheers
Vassilis
Hi Vassilis,
I’m not sure, sorry. I’d like to do it in the coming two weeks; what I need is a few spare hours on an evening or weekend; lets see. All the best, Matthijs
vassilis-bourdakis avatar image vassilis-bourdakis mvader (Victron Energy) ♦♦ commented ·
no worries, indebted anyway with your brilliant work!
V.
