vga avatar image
vga asked
Venus OS v2.70 - Wifi not working on raspberrypi
Testing Venus OS v2.70~15 on an Raspberry PI 3B+ and I'm not able to get the WiFi to work. Worked as expected on 2.66, but on 2.70 I just get the message "No Wi-Fi adapter connected" Any other experiencing this or have any tip to make wifi work?
vga
Venus OSRaspberry Piwifi
rzaenger avatar image
rzaenger answered ·
Hi, try on shell
> connmanctl (enter)
> enable wifi (enter)
than check on display if WiFi coming up.
BR Roland
5 comments
ray-mont avatar image ray-mont commented ·
@rzaenger I will check that later today
ray
@rzaenger
Perfect Wifi is working Again
Thanks for the Help
Ray
rzaenger avatar image rzaenger ray-mont commented ·
With pleasure!
Roland
vga avatar image vga commented ·
Running the commands from shell did the trick. I now have WiFi again, Thanks @rzaenger :)
vga
squowse avatar image squowse commented ·
Thanks a million. Worked for me too. Raspberry PI 3 Model B. Venus 2.73. Connected through iOS Victron Connect App but showed no wifi networks
Kevin Windrem avatar image
Kevin Windrem answered ·
I'm running v2.70~15 on a RPI 4 and the internal Wi-Fi works fine.
From ssh or other console connection, type ifconfig and see if there is a wlan0 entry. If not, something in the kernel isn't correct, maybe a missing device overlay????? Or maybe the internal Wi-Fi isn't working. Try booting to Raspberry PI OS to see if it works there.
When I run ifconfig, there is no wlan0 entry. Wi-Fi works correct with the 2.66 version of the Venus OS and with Raspberry Pi OS.
vga
ray-mont answered ·
Same issue here
I thought my pi 3b+ was broken
rebooting will not solve this, tomorrow will test an older firmware
My RPI 3B V1.2 does not have this issue
ray
Forgot to mention that its the internal Wi-Fi. This one is revision 1.3 as well
vga
ray-mont answered ·
@vga @mvader (Victron Energy)
just tested 2 Raspberry PI 3B+ no version number on both boards and
WiFi works OK on one
but on the other Raspberry PI 3B+ it does not work with 2.70~6 nor ~15
it can’t find the WiFi adaptor
going back to version 2.66 and WiFi is working again
for me this is not an issue as I normally do not use the WiFi “ons tuintje”
ray
Hi @vga thank you for reporting this. It 1sounds like some driver issue. You could type dmesg (and post it here), perhaps that helps in fixing this.
For now, I'm hoping someone else here can lend a hand, we have our hands full with releasing v2.70 as is, without spending any consideration on the raspberrypis; and will look at that only later.
Attached file with the dmesg output if anyone wants to look into it
dmesg.txt
vga
dmesg.txt (19.1 KiB)
Hi all, could you try this again, with v2.70~19?
That version is available for field testing since this morning.
note that the best test is to flash a new image to the sdcard, and then insert that into the pi, and see if you can configure the wifi from the screen and/or remote console.
Tomorrow morning I wil try it
ray
It works no issue Wifi adaptor
It was found from a clean install with 2.70~19
Ray
don-davici avatar image
don-davici answered ·
I installed the newest 2.72. I had my system up and running with the 2.6 version. My dongle worked perfectly. With the new version the follwing message comes up in dmesg:
usb 1-1.2: new high-speed USB device number 7 using dwc_otg
[ 175.823447] usb 1-1.2: New USB device found, idVendor=2357, idProduct=010c, bcdDevice= 0.00
[ 175.831852] usb 1-1.2: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 175.839275] usb 1-1.2: Product: 802.11n NIC
[ 175.843580] usb 1-1.2: Manufacturer: Realtek
[ 175.847887] usb 1-1.2: SerialNumber: 00E04C0001
[ 175.854117] Chip Version Info: CHIP_8188E_Normal_Chip_TSMC_D_CUT_1T1R_RomVer(0)
[ 175.913522] r8188eu 1-1.2:1.0: Direct firmware load for rtlwifi/rtl8188eufw.bin failed with error -2
[ 175.922760] r8188eu 1-1.2:1.0: Firmware rtlwifi/rtl8188eufw.bin not available
[ 175.929907] MAC Address = 28:ee:52:17:50:88
[ 175.962361] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
[ 176.163659] usb 1-1.2: USB disconnect, device number 7
[ 176.169797] R8188EU: indicate disassoc
Seems like the driver is not compiled anymore. Would be great if this dongle could work again. Any hints?
Best
kivanov avatar image kivanov commented ·
Try installing:
opkg update
opkg install linux-firmware-rtl8188
xanderb avatar image xanderb kivanov commented ·
Realising this is an old thread I’m trying to get an USB wifi-dongle working on a rpi2.
opkg update doesn’t work on VenusOS 3.30 due to: file_mkdir_hier: Cannot create directory ‘/usr/lib/opkg/lists’: Read-only file system.
Any suggestions?
ludo avatar image
ludo answered ·
I installed version 2.89 on my Pi 3b+, no WiFi, no Bluetooth ?
ifconfig doesn't show the adapter, right now I'm using USB-tethering to my phone, remote-desktop, PuTTY and VRM are up and running, I connected my BMV712 through a ve-direct cable, it works ;)
thx for some help
Victron Venus OS Open Source intro page
Venus OS GitHub (please do not post to this)
Raspberry Pi running Victron’s Venus firmware - Blog Post
Venus OS Large image: Signal K and Node-RED - Install
raspberrypi install venus image
