ehspill avatar image
ehspill asked
Looking for old Doc "VE - Interfacing with the Phoenix Product Range”.
Hey,
im looking for an old doc regarding interfacing with old VE.9Bit Devices
It is referenced in an stil lavailable document about interfacing with an mk2 adapter
https://www.sv-zanshin.com/r/manuals/victron-interfacing-mk2-protocol-3.12.pdf
For communicating with older (VE 9-bit RS485) products, refer to “VE - Interfacing with the Phoenix Product Range”.
i know old devices can not communicate with venus but i also know old devices can talk to the current victron config 3 app through an mk2 adapter talking ve.9bit.
i have an old multi around where i can configure and connect trough the current victron config 3 app with an mk2.2b usb to serial adapter (for communication handling see the linked pdf chapter 3.4.
with the old doc i hope to get more insight about the communication to create an open source driver for venus integration in combination with an mk2 adapter.
any help/info is greatly appreciated, victron won't supply the old doc sadly.
if anybody could send me the doc i would be very thankful -
mail: victron@allthingscitrix.com
MultiPlus Quattro Inverter ChargerVenus OSVEConfigure 3
helge-1 avatar image
helge-1 answered ·
Looking for the same document.. Let me know if you find it anywhere!
Mike Dorsett avatar image
Mike Dorsett answered ·
I Have "Interfacing with VE.Bus products – MK2 Protocol" which may cover what you are looking for.Interfacing-with-VE-Bus-products-MK2-Protocol-3.12.pdf
I've currently got a Mk2 and a VE direct plugged into a pi to monitor my Solar system, the Pi also runs the BMS, Modbus server and Web server for the user interface.
Also found https://github.com/izak/ib.victron which is a python lib for the Mk2.
