jaqibar avatar image
jaqibar asked
Multiple Pylontech Banks connected to cerbo
Can I use the two BMS ports for two separate Pylontech banks and then connect a third bank of Pylontech for a third a bank on the CAN-bus? Will I still have full communication between battery and GX with normal operation?
cerbo gxBMSPylontech
markus avatar image
markus answered ·
no - this is not possible.
To connect multiple Pylontech battery towers to your system, you will need the Pylontech lv hub.
jaqibar avatar image jaqibar commented ·
Hi Markus. Thank you for the reply. That is what I thought is going to be the way to go.
Marc Heymans avatar image
Marc Heymans answered ·
What cable do you use for the communication between the hub and the cerbo. I have tried The victron cables (type B and Type A ) and zero comms.
I am using 18 US2000 and a LV hub
