hiaslgruber avatar image
hiaslgruber asked
Multiplus 2 and Pylontech US 2000 Plus usable without GX device?
I have an off-grid system with a Multiplus 2 , two Bluesolar Mppt 150/35 and 8 Pylontech batteries US2000Plus. Yesterday the Color Control GX stopped working (first it showed wrong values, then I tried to reboot but it remains with the "Victron Energy" start display).
As the Mppts stopped to charge I disconnected them from the CC and reset them with the parameters for Pylontech batteries. Now they charge correctly, short time after 100% SOC they change to absortion modus, and the Pylontechs go standby when fully charged and if there´s no load. Also the Multiplus works properly.
Can I continue to use the system in this way without any GX device or should I better shut it down until the new CC arrives?
Multiplus-IIPylontechgx device
Alexandra avatar image
Alexandra answered ·
@hiaslgruber
I have not tried with the multi 2 but the manual states not to as it needs the keep awake.
https://www.victronenergy.com/live/battery_compatibility:pylontech_phantom
See section 1.2
I dont know how your supplier stands on this but ours will not honour warranty on Pylons in an ess system if there is no GX device.
Matthew Walsh avatar image
Matthew Walsh answered ·
have you tried this procedure with your current CCGX?
https://www.victronenergy.com/live/ccgx:firmware_upgrade_to_v2
