Hello
At what temperature will a quattro or ccgx warn and alarm?
And what action will be taken?
Harold
Hello
Harold
The temperature sensor connected to the Quattro is used for temperature compensation of the charging. It is not used for alarms, a readout is not available either.
When connected to a CCGX, then the temperature sensor can be assigned as a battery temperature sensor and then the values used for Shared Temperature sense for example, the values can be read and are also visible in VRM.
did you sort this ?
@WKirby: I see the CerboGX has default alarms. if no custom alarms are setup at what temp will the inverter alarm at ?
thx
54 People are following this question.
