massimo avatar image
massimo asked
Installing IP22 battery charger
Hi there. Can I use a AWG 11 (4 mm2) wire to connect the IP22 12V/30A to three 74 Ah/680A wet batteries, at a maximum distance of 2,5m? Also, shall I install fuses between the charger and the batteries? If yes, how many Ampere? Thank you in advance for the hints. Max.
chargerwiringinstallationfuses
Victron Wiring Unlimited Book
