jm0278 avatar image
jm0278 asked
Multiplus-II Fuse/Wire Size Conflict?
I have a Multiplus-II 12/3000 2x120 and a Lynx Distributor on order and am trying to finalize my wiring configuration. The manual for the Multiplus-II calls for two AWG 1/0 battery cables. But it also calls for a 400 amp fuse! According to my research, an individual 1/0 cable is only rated for 350 amps maximum so a 400 amp fuse on each 1/0 cable would not be adequate. Am I missing something?
I'm thinking of using a single 400 amp fuse in the Lynx Distributor with 4/0 wire running to a Victron On/Off switch, then somehow getting the two 1/0 gauge wires connected between the output side of the switch and the Multiplus-II. Suggestions?
Thanks.
Jim
Multiplus-IIwiringfuses
Kevin Windrem avatar image
Kevin Windrem answered ·
The fuse size is for total current, so if you run two separate wires, you'd need a fuse of half the rated size in each wire. So come off two fused outputs of the distributer with 1/0 wires and 200 amp fuses for each. Make sure the wires are equal length in order to balance the currents.
Remember, at these currents, every connection is a resistor. That is, even low resistance connections will exhibit a voltage drop based on the connection's resistance.
wkirby avatar image
wkirby answered ·
The 400A fuse would be rated for the run of two 1/0 cables together. You would not be providing a 400A fuse for each individual 1/0 cable.
You can run a single 4/0 cable to your diconnect switch and then two 1/0 cables out of it on towards your MultiPlus. The 400A fuse would be fine for the 4/0 cable and also the two 1/0 cables as a pair.
Alternatively, take a 4/0 cable from the switch to the cable if that's easier.
