thedussst avatar image
thedussst asked
Ip65 stuck in storage mode
I have an ip65 blue non smart charger and a mppt solar controller installed in my offroad caravan. I noticed that my agm battery almost competely discharged while plugged into 220v. The ip65 still being in storage mode. Thought it could be as a result of mppt controller but parked under roof so solar also not charging.
Is the ip65 not supposed to wakeup and move to bulk? Any ideas what could cause this and how to fix? Ip65 is non blue tooth so cannot update settings.
battery chargingchargermppt chargingip65
@TheDussst
Sometimes just a disconnect from 220v and a few minutes for internal electronics to discharge then reconnect does the trick. Maybe heat or something has caused a program glitch? Not sure, mine does it on occasion.
