spokiter avatar image
spokiter asked
Mppt 100/15 charging problem
Hi Community,
I have some problem with my new Mppt 100/15 blueSolar charger. The charger doesn't charge my battery ? Can you help me ?
Follwing parameter.
2 Büttner Panel MT SM 110 MC
1 Battery 180Ah Lithium LiFePO4
1 MPPT 100/15 BlueSolar charger
Solar volt: 20,93 v
a = 0a
Battery volt = 13,19 v
setting in mppt charger: i use the default profil: Lithium Iron Phospate (LiFePo4).
12 Volt setting
max ah: 15a
The last 3 days, my camper war parked in sun.. But the battery is not load for a second.
Thanks for your help
Daniel
battery chargingsolarmppt charging
Did you checked all fuses between the MPPT and the battery?
There is also a 20A fuse directly at the MPPT next to the connection terminals.
spokiter answered ·
Yes, I check the fuses ( was ok) , but also put an new fuses in the mppt.
spokiter answered ·
I think there is no more fues between the mppt and the battery. (A company did the installtion of the solar , mppt and the battery..
