daveybdublin avatar image
Cerbo GX Gas Alarm Question
New to this so please bear with me.
Does anyone have any thoughts on configuring a gas alarm with solenoid shut off valve via the digital inputs and relay port on the Cerbo GX? I'm looking at a gas alarm setup (BEP Gas Detector) with two sensors and solenoid but its working out very expensive, £300+. Wondering if there may be a better way to use a simple gas detector and solenoid (gas rated) for this with the Cerbo GX?
Venus GX - VGXcerbo gxRelay
Kevin Windrem avatar image
Kevin Windrem answered ·
Why not just connect the gas detector directly to the solenoid?
You could connect the gas detector up to a Venus digital input and have that sound an alarm but there's nothing specific for such an input. The digital inputs could maybe trigger a generic alarm relay but that would include other alarms (like low battery voltage).
I could connect the alarm to the solenoid directly, but I was thinking about whether it would be possible to route via the GX and using the portal as a remote shut off switch for gas supply if needed...
