David avatar image
David asked
RELAY controlled easily over VRM
It would be useful to be able to change the state of a relay via VRM for example that could control a load remotely. IE - turn an airconditioner if it had been left on accidentially . At the moment a customer is using the relay in the MPPT to do this function but this is not ideal.
VRMRelayfeature request
Alexandra avatar image
Alexandra answered ·
@David
What GX device are you using?
Most gx devices have a relay in them that can be programmed and accessed through the interface.
The cerbo has two, one for generator start stop and one to manually turn on and off. You can set it to be normally open or normally closed.
Settings - relay - function...
VRM login page
VRM documentation
VRM API documentation
How to change the Owner of a VRM installation
The feature requests topic tag can help Victron R&D find feature suggestions for products.
There are many factors that go into the Victron product roadmap, and feedback from end-users can help.
