Javier Moran avatar image
Javier Moran asked
EasySolar 12V/1600
Dear community, good afternoon
I have an EasySolar 12V/1600.
Is it possible to connect VE.Bus BMS + LiPoFe4 Smart batteries to it without using a GX interface?
Thanks for your comments,
Best regards,
Lithium BatteryBMSEasySolar All-in-One
Alexandra avatar image
Alexandra answered ·
@Javier Moran
The ve bus connects directly to the multi and so communicate directly with it, so I don't see why you cannot just do that.
It has led indicators to let you know what is going on as well.
It's job is to disconnect loads or charging depending on the necessity, so as I understand would be independent of any other system Just be sure to load the assistant for it.
https://www.google.com/url?q=https://www.victronenergy.com/upload/documents/Datasheet-VE-Bus-BMS-EN.pdf&sa=U&ved=2ahUKEwjH9aLk3-juAhUgXhUIHTqoA3kQFjABegQIARAB&usg=AOvVaw2T6IXas59TxKK_l_MfPh6u
They can even be used in no ve bus products like the phoenix which has no monitoring really to speak of. You can find system examples in the manual liked above.
Javier Moran answered ·
Thanks Alexandra!
