stocksy avatar image
stocksy asked
Updating Multiplus firmware with VE.BMS BMS on Lithium bank
I'm trying to update the firmware on my Multiplus, but it says to disconnect the BMS. If I do that it will shut down the multiplus, so bit of a catch 22.
Do I need to remove the Lithium/Assist settings, disconnect the BMS and then do the update and put the Lithium/Assist setting back once the update completes?
Thanks,
Michael
Lithium BatteryBMSfirmware updatemultiplus ve.bus
Just continue with the update process. The Multi shouldn't be turned off completely without the BMS.
If it is a Compact Multi you may have to switch the DIP-switches back to default for the update process.
stocksy avatar image stocksy commented ·
Thanks Matthias - I thought I'd disconnected the BMS before and the Multi shutdown - Guess not I'll unplug the BMS and see what happens. Regards, Michael
Battery Compatibility
Victron VE.Bus BMS product page
Victron 3rd party BMS compatibility page
