miya avatar image
miya asked
Smart BMS CL 12V 100A - Charge and Load Disconnect
Hi All
I am planning using the BMS CL to sit between Lithium house batteries and Alternator. I plan connecting the BMS CL to my EasyPlus with the 'Cable for Smart BMS CL 12-100 to MultiPlus' (PN: ASS070200100). This mean the load / charge disconnect plugs on the BMS CL are now being used by the EasyPlus.
My problem is - I have other loads / charging sources (independent of the EasyPlus) that I also want to disconnect when the BMS commands it.
Can I simply tap addition wires in to the load / charge disconnect terminals on the BMS CL - to control multiple battery protection devices ?
Regards
Tim
Lithium BatteryBMSVenus GX - VGXBattery ProtectEasyPlus
