nico avatar image
nico asked
Lithium batteries not charging from shore power
I have 2 x 200ah lithium batteries from victron.... they charge through a multuplus 12/3000 on shore power and typically charges fully in 90 min or less.
Now my batteries and multi aren't "activating" when the shore power is on..... is this temperature related? It just got to freezing temps around my area, the batteries on the app say they are at 50° +.....
In the settings for the batteries it looks like thisscreenshot-20201109-160712.jpg
Its approx 40° outside......
Any help appreciated. The system worked well for quite some time, only the ambient temps have changed so I'm curious if my settings are wrong or if I simply need a battery warmer of some sort....
Multiplus-IIbattery chargingshorepower
asea avatar image
asea answered ·
Have you checked the AC voltage input? If the voltage Is too low the multiples will not charge.
VictronConnect VE.Bus charging manual
