mikko-juuti avatar image
mikko-juuti asked
AGM charging current selection on Dolphin charger
Hello everybody,
I have 3 x 12V 95Ah AGM's in parallel and plan is to charge the bank with Dolphin charger when connected to shore power.
Which of below modes you'd choose for setup? If I got it right, "Calcium lead" mode would have the right voltages? I'm planning to use one of the posts of charger to connect the starter battery which is a traditional 12v battery so it would need the "Wet & flooded" option but which one you see would be a best option for this combo with 3 AGM and one wet battery?
Cheers, Mikko
battery chargingAGM Batteryshorepowerbattery connection
wkirby avatar image
wkirby answered ·
When setting up charging profiles, you need to get the information from your battery manufacturer's datasheet and then work from there to set up your charger correctly.
Also, we shouldn't really advise on the Dolphin charger because this community is a knowledge base Victron equipment only.
VictronConnect VE.Bus charging manual
