D S avatar image
Split Phase Quattro reading AC input voltage but showing 'Active AC Input Disabled'
Not able to charge batteries. Quattros don't seem to go into charge mode. Voltage readings are present on AC input but Cerbo shows 'Active AC INPUT DISABLED'.
Looking for someone who can help remotely? Willing to pay for system review and configuration help.
Setup:
240V Split phase - 2 Quattro's 24v/5k/120v - 100A Autotransformer
1200Ah Pylontech compatible batteries (3 400Ah in parallel)
220v / 60hz Shore power
10kw Generator
MultiPlus Quattro Inverter ChargerLithium Batterybattery chargingAutotransformersplit phase
Hi @D S
what you can try:
-measure AC voltage between phases: is it double of the two phases then it's a real split-phase connection. if lower it is probably two legs of a 3 phase connection and not 180 degrees.
-unselect 'switch as group' so the system will use a single phase input
Hi
Did you select the good split phase set up (dualphase 120, 180 or 240 !)
If not, the system will detect the phase but can't synchronise to it !
