jond avatar image
jond asked
Are my MultiPlus II VE Config charger settings correct for 4 x Omnipower 200Ah batteries?
Just want confirmation on my settings. Help will be appreciated. The ones in bold I'm most worried about.
Stop after excessive bulk checked
Lithium batteries unchecked
Storage mode checked
Use equalization (tubular plate traction battery curve) unchecked
Charge curve Adaptive + BatterySafe
Absorption voltage 57.60 V
Float voltage 54.60 V
Charge current 35 A
Repeated absorption time 1.00 Hr
Repeated absorption interval 7.00 Days
Maximum absorption time 8 Hr
Temperature compensation -72.0 mV/deg
Battery Specsheet: Omnipower-240.pdf
The system is a MultiPlus II 48/3000/35-32 with 4 x OmniPower 240AH batteries as a backup system. I'm using the BMV700 as a battery monitor. Venus GX.
Multiplus-IIchargerVEConfigure 3voltagelead-acid
omnipower-240.pdf (181.6 KiB)
