floyd avatar image
Modbus via RS485 Serial USB on CCGX has intermittent responses
I am building my own Lithium BMS for my Victron setup using the example python scripts.
When my RS485 USB Serial adapter is connected to a Raspberry Pi (latest Raspbian), I am able to reliably read the appropriate registers from the lithium batteries without any errors. However, when connecting the same adapter and running the same python code on the CCGX, I only get a successful response very intermittently.
Does the CCGX lock the USB port? Or is it a pymodbus version issue? What can I look for?
Lithium BatteryCCGX Color ControlBMS
Hi @floyd
I've moved your topic to the 'modifications' area.
Hi Floyd, check the here, and then especially the topics around serial-starter:
https://github.com/victronenergy/venus/wiki/howto-add-a-driver-to-Venus
Thanks @mvader (Victron Energy) - this answers my question. (I probably should have done a better search...)
