Think I might have accidentally disconnected the venus wifi, how to reset in order for venus to transmit again?
Thanks for the reply. I connected my laptop (wireless connected to internet) with RJ45 cable on LAN port of inverter, can't see device on network overview
Hi @HDP
I don't know what you've done here, nor what your lappy is. But typically you'd have to 'Share' your lappy's wireless www link to have the GX allocated a dhcp LAN address. (via RJ45 ethernet port)
If that's successful, VRM will connect, and you can just type "venus.local" into a browser tab and you should have functional access to the GX screen.
EasySolar-II GX 3000 & 5000 product page
15 People are following this question.
SmartSolar MPPT 150/85 VE.Can - No current flow in Bulk with PV at VOC
Large difference between solar blanket voltage output and Victron dashboard
Are 50vdc solar panels wasted on a 12vdc system?
Japanese RV Build— Stuck on Bulk / Configuration Review
Will EasySolar 48/5000 run as inverter and charger at the same time?
