swan38 avatar image
IP22 strange behaviour
Hi all, just installed an ip22 30a 3 output charger. Turned it on and the readings are all over the place. Amps are varying from 0-30 rapidly. I’m seeing 1.2 amps . 7 amps and every other number between. A multimeter shows the charge voltage fluctuating as well. Is this normal behaviour? How can I test?
battery charging
kai avatar image
kai answered ·
Make sure there's no loose connections, and do a tug test on all crimps.
