muis avatar image
Victron MultiPlus stays off
I have a Victron MultiPlus 12/1600/70, which doesn't work anymore after this winter. After measuring it seems there is nothing wrong with the 220v wall power that goes to the device, but it just doesn't turn on (no LEDs burning).
Could the reason be that my accu's are fully empty? Or should the device always turn on when connected to the 220v power, even when the accu's are broken/empty?
Because since it is also responsible for charging the accu's, it doesn't seem logical that it doesn't work with empty accu's.
So in case the state of the accu's have nothing to do with it, what else could be responsible for the device to stay off?
MultiPlus Quattro Inverter ChargerMultiplus-IIbattery chargingvictron products
Paul B avatar image
Paul B answered ·
If your battery are fully flat then this would be the cause. try connecting to a diferant battery, or at least put a volt meter on the battery and check
I could connect my multiplus to grid 220v as Victron does in their demo videos without battery/solar etc. and configure it. Maybe worth trying without a battery?
