duffer41 avatar image
duffer41 asked
RV Inverter Upgrade: 12v vs 24 Inverter
RV Upgrade; The coach has on onboard 4kw generator that will be used to charge the batteries in addition to the 950w solar panel array.
I am going to be running 4x 12.8v 200ah lithium batteries and deciding whether to run as 24v paired with a 24/5000 Quattro or run as 12v paired with 12/3000 Multiplus.
If I go the 24/5000 route I am having the panel upgraded from 30amp to 50amp. The quatrro has a much beefier charger in it and will almost cut charging time in half compared to the Multi-plus so I am leaning that direction.
Other than faster charging and additional power headroom, what else am I not considering as potential downsides or upsides to the 24/5000 setup vs the 12/3000 setup?
MultiPlus Quattro Inverter Chargerbattery chargingPhoenix Inverterinverter current draw
kogir avatar image
kogir answered ·
Unless you don’t have any 12V loads you’ll still need a way to power those.
