jayw avatar image
jayw asked
LiFePO4 / LFP Monitoring Options
A theoretical system outlined below, with DC loads only.
- Smart Solar MPPT 75/10 (+PV)
- VE Bus BMS
- LFP Smart 12.8 150Ah
- Battery Protect BP-65
Noted that there is local Bluetooth monitoring for MPPT and smart battery. However, if monitoring is required on VRM/online what options are available?
My understanding is GX devices can be interfaced by to a VE Bus BMS via a Quattro or Multi. Any other options?
VRMLithium Batterygx devicemonitoring
wkirby avatar image
wkirby answered ·
The VE.Bus BMS can control the battery protect directly, you do not need to have a VE.Bus device. Likewise a GX device can monitor a DC only system such as you propose.
jayw avatar image jayw commented ·
Thanks for the reply ...so the GX device and the BMS can operate independently of each other?
wkirby avatar image wkirby ♦♦ jayw commented ·
Correct, the actual VE.Bus connection is not necessary unless you have a MultiPlus or Quattro.
