energy avatar image
energy asked
Connecting Multiplus outputs in Parrallel
Apart from the VE.Bus cabling, which software has to be loaded onto the Multiplus 2 inverters before outputs can actually be connected to each other?
Multiplus-IIbattery charging
Murray van Graan avatar image
Murray van Graan answered ·
You would need to make sure they are both running the same firmware. Then, setting them up in parallel can be done via Ve.Bus quick configure. Contact me should you need help, I have a .co.za email account too
MultiPlus-II Product page
MultiPlus-II Manual
MultiPlus-II 230V Datasheet
VE.Bus Error codes
