bigal avatar image
VRM+BMV712 - No Batt Temp
I have recently hooked up my BMV712/MPPT Solar to VRM portal via VenusOS - its really great and loving it so far.
I have battery temp being fed into the network by Smart Battery temp sensors. And this works as I can see Batt Temp on the solar? (or was it the BMV?)
Anyway - I was wondering if I am doing something wrong as despite the battery temp being on the network, it is not passed through to VRM.
Thanks
Al
BMV Battery MonitorVRMTemperature Sensortemperature
mtnbrit avatar image
mtnbrit answered ·
The starter battery voltage is also not working on VRM. Seems like it should be an easy fix.
bigal avatar image
bigal answered ·
Just confirmed - yes its the smart solar that gets the temp. It doesn't seem to pass the temp on to the BMV for some reason.
6 comments
Hi @bigal
That is correct, it's only transmitted to the MPPT's
But I think that since recently, it should also be visible on VRM:
2019-11-06
  • Added a battery temperature graph widget for solar chargers
  • Added battery temperature to the solar charger summary widget
https://www.victronenergy.com/live/vrm_portal:change_log
christofferbengtsson avatar image christofferbengtsson Daniël Boekel (Victron Energy Staff) ♦♦ ·
Hallo @Daniël Boekel (Victron Energy Staff),
I didn't want to start a new thread but I have the exact same issue as described above. The temperature is available in the Victron Connect app but does not feed into the Venus OS/VRM portal. I have enabled DVCC but "used sensor" is blank. When I try to plot the temperature data in VRM I get "No data available".
My setup is:
MPPT 100/20. Firmware: v1.49
BMV-712. Firmware: v4.03
Raspberry Pi 3b+ running Venus OS v2.60~19
Smart Battery Voltage/Temp bluetooth sensor connected to the MPPT using VE.Smart Networking.
Can you help me understand what I am doing wrong?
Best
Christoffer Bengtsson
Hi @ChristofferBengtsson
I've just learned that the temperature is not (yet) forwarded to VRM, hopefully it will be in feature firmwares.
Hi @Daniël Boekel (Victron Energy Staff),
This is really a shame but it does explain why I am not seeing any data. It would be great to have this feature implemented. Is it part of your current firmware/software roadmap for Venus/VRM?
It's on the wish-list to implement.
Awesome! I will look out for it then. Is it a limitation in Venus OS or VRM?
