Hello, after installing the v552 Firmware to my MP the Charger stays in absorbtion or float.
Generator runs, but the SOC goes still down.
In the CCGX Display shows me, no BMS.
What can i do?
Best regards Robert
What can i do?
Best regards Robert
Hello, a few hours later with running generator nothing really happened.
SOC still goes low.
And nomore passtruh (Durchleiten)
Best regards Robert
I've been saying this a lot lately - why are you updating firmware on healthy systems? There is no need to constantly upgrade unless you need what is in it.
It is not a mobile phone.
Did you restore your settings after the update - as it gets wiped and the most common issue is end users who fail to reload the config properly, something which is very easy to check.
Victron VE.Bus BMS product page
Victron 3rd party BMS compatibility page
Remotely Update VE.Direct Firmware
VictronConnect manual / Firmware updates
Updating a Victron Smart Solar MPPT Charge Controller with Victron Connect
VictronConnect configuration guide for VE.Bus products - Firmware Updates
60 People are following this question.
