notger avatar image
notger asked
CCGX compatible BMS Device for 6s Li-ion batteries ?
Id like to change my Lead-acid 24 Volta battery to a 24Volt Li-ion Tesla batterie module.
Each module consists of six "cells" of nominal 3.6vdc consisting of 74 Panasonic NCA 18650 cylindrical battery cells of approximately 3.2 Ah capacity in parallel. This 6S74P configuration then features a nominal voltage of 21.6v at 233 Ampere-hours for 5032 Watt-hour capacity.
Expl.: https://hsrmotors.com/products/battery_modules
So the Question, do you know of any BMS system that is compatible to the CCGX.
Maybe even with DVCC functionality, or just logging and monitoring.
Greets and thanks
Gernot
CCGX Color ControlBMSDVCC
Murray van Graan avatar image
Murray van Graan answered ·
Hi @notger, have a look at this http://www.rec-bms.com/BMS.html
notger avatar image
notger answered ·
this thing looks great, exacting the price
what is shown at the ccgx..if the recbms is connected ? could someone post a screenshot,cause in the manual or in the website i could not find anything about the functionality comined with the ccgx
do you see the individual cell voltages, or if there is balancing going on.
will balancing be logged and visible in the vrmportal to find out about the balance habbits of the batterie
greets and thanks
gyrogypsy avatar image
gyrogypsy answered ·
The www.electrodacus.com BMS is better, cheaper, and has the best customer support of any company I have ever dealt with. I am using two SBMS0 with two Tesla S batteries in my Navion RV. Works excellent.
