Manuel Donati avatar image
Manuel Donati asked
Connecting BMS V2 - Venus GX and Multiplus compact 12/1600/70-16
Hi all,
I have an off-grid system and would like to install a LiFePO4 Battery 12.8V/200Ah SMART with BMS V2.
I currently have a MultiPlus Compact 12/1600/70-16 firmware 510 first version, a venus GX firmware v3.32, a BMV-700 firmware v3.11 and 2 X MPPT 100/30 firmware v1.64
On the BMS instructions I read that I have to install a VE.Bus BMS Mains dedector on the multiplus as it is old model.
If instead of connecting the multiplus to the BMS I connect it to the venus should I still connect the VE.Bus BMS Mains dedector?
BMSVenus GX - VGXmultiplus ve.bus
