hello guys can u connect smart solar 250/100 with a ve direct cable or with ve bus to my multiplus 2 without buying a cerbo gx?
If you mean panels to mppt, mppt to battery, then yes.
If you mean connected to the inverter directly for communication, then no. The ve bus is not designed for that. You need a GX.
But it will still work as a stand alone solar charger when there is no communication anywhere.
160 People are following this question.
Cuantos mmpts puedo conectar a un sistema con cerbo gx y multiplus 2
Lab power supply + MPPT + Multi
Can you tell the Hardware Version from Serial Number? (Multiplus)
Where does Cerbo get the DC (battery) voltage from
What does the CerboGX add if I have Smart Dongle, Smart Shunt, Smart Solar MPPT and Multiplus?
