Henning Lillehagen avatar image
VE.Direct splitter/ hub
I would like to connect 2 pcs Blue Solar MPPT solar charger in addition to 1 pcs BMV-712 battery monitor to a Color Control GX, but as far as i know the Color Control only got two VE.Direct ports. I would need three.
Is there a VE. Direct splitter or hub that will allow me to connect all my items with VE. Direct?
Or is there another solution to my issue?
CCGX Color ControlBlue Smart Chargerbmv 712
Hi; please read this Connecting more than two devices to your CCGX using VE.Direct section in the CCGX manual; it explains how to do this by using the USB ports. If there are not enough; use a (powered) usb hub. And take note of the max number of devices. All explained in detail in that section in the manual.
2 comments Share
Hey @mvader (Victron Energy) and @Guy Stewart (Victron Community Manager) please note that the MP2 GX datasheet and the "note 14" at https://www.victronenergy.com/live/venus-os:start#notes contradict one another.
The datasheet says: "A VE.Can interface. This can be used to connect to Victron VE.Can devices (eg VE.Can MPPTs), or the port can be reconfigured via the Remote Console for use with a compatible CAN-bus Li-ion Battery."
Note 14 makes it clear that the VE.Can port on the MP2 GX devices cannot handle VE.Can MPPTs.
Thanks @warwick,
The Note 14 is correct, the CANbus port is limited to BMS.
I will ask that the mistake in the data sheet is corrected now.
Markus avatar image
Markus answered ·
Just in case anyone is searching for a cheap and good working USB Hub:
I tried several cheap ones for connecting my USB VE.Direct devices and after some frustrations with non stable USB Hubs, causing single devices stop reporting to Venus from time to time, I bought this one and it works rock solid and stable:
https://www.digitus.info/de/produkte/computer-zubehoer-und-komponenten/computer-zubehoer/usb-hubs/da-70216/?pdf=1
I use it without external power. But it would be possible to power it externally too.
Markus
3 comments Share
Thanks @Markus Your link isn't working anymore but I got it from here:
https://www.amazon.com/gp/product/B004BU8HWI/ref=ppx_yo_dt_b_asin_title_o03_s00?ie=UTF8&psc=1
This has been great because the VE.Direct cables are so fat they can't fit in a normal hub. I have 1 VE.Direct, 1 MK3 USB, 1 flash drive for data logging and 1 GPS hooked up to a USB extneder/amplifier to my Venus Pi and it's working great.
There were new model VE.Direct to USB cables released at Intersolar. Nice and thin now :)
nebulight avatar image nebulight Guy Stewart (Victron Community Manager) ♦♦ ·
Awesome! It actually still worked out better for my install as I only needed to run a single USB cable rather than all of them, but good to know!
Dosheimer avatar image
Dosheimer answered ·
I have a MPPT 50/100 without Bluetooth. So I bought an additional Victron Bluetooth Smart Dongle some time ago and successfully connected it with the MPPT 50/100. Now I would like to connect the MPTT/100 via VE.direct to USB cable to another device but would like to use the bluetooth dongle also, but there is only 1 VE.direct port at the MPTT 50/100. The bluetooth dongle has no USB therefore a USB hub does not seem to work for me. What can I do to connect the MPPT 50/100 with the bluetooth dongle and with an VE.direct USB cable (to connect it to an Raspberry Pi 3 B or B+) at the same time?
1 comment Share
That's not possible.
The only thing you can do is to exchange the the Blue Solar with a Smart Solar. So you have build-in Bluetooth and you can use the VE.direct port to connect it to the rPi.
Or you can use this feature:
https://www.victronenergy.com/blog/2020/04/06/victronconnect-v5-20-connect-configure-remotely/
manowell avatar image
manowell answered ·
Any way to do one more?
2 comments Share
As others have already written: just a usb hub is possible. Splitting doesn't work because of technical reasons.
fcriado avatar image
fcriado answered ·
You can use a VE. Direct to USB adaptwr and connect via USB to the CCGX.
Cheers!
Share
