David Barnes avatar image
David Barnes asked
How to install an Orion TR in a class C camper with isolation/boost switch
I have a 2017 Minnie Winnie 27Q with a stock lead acid setup along with battery boost switch. I am converting to Battle Born lithium batteries. I bought an Orion TR 12|12-30 to charge while on the go and understand how to hook it up in terms of in from alternator, and out to lithium. My question is: which lines are which in the solenoid and do I need to disable the boost switch/relay once I've determined which lines come from alternator and which go to the battery?
Is RED from the alternator/chassis batter, YELLOW to my house battery? If so, what is the GREEN?
Lithium Batteryorion dc-dcalternator
Battery Compatibility
Victron DC to DC Converters Product Range
__________
