ajaja avatar image
ajaja asked
Orion-Tr DC-DC Converter Settings
I just got my Orion-Tr DC-DC Converter Isolated 12/24 V 15A charger, and what to configure setting for my environment.
I have limited understanding so my questions may be lacking. I will elaborate when needed. Also will appreciate advice and direction to concepts I missed here.
I have multiple 24V batteries in parallel all connected to busbars. Do I run the Output wires to the busbars?
I know my battery's voltage range is 21V – 29.4V. What do I set Bulk and Float to?
My alternator has a fixed voltage of 14.2V.
Absorption Voltage: 29.2?
Float Voltage: 27.6?
Caveat, I plan on limiting my driving to less that six hours a day when I do drive.
What are the Bulk time limit and Re-bulk Voltage Offset?
Oh - and Adaptive Absorption?
Lock-out I assume has to do with chassis batteries. I never want them to drop below 11V. Is it here that I input that setting? (12.3 - 12.9)
Engine shutdown detection, do I set this something like 12v - 13.8v?
Thank you.
Battery:
Voltage: 24V
Voltage Range: 21V – 29.4V
Capacity: 95Ah (2.3kWh)
Power (Amp): 100A Continuous, 200A Peak
Configuration: 7S 20P
Alternator:
Prestolite A0014949PA
Output 270 amp
Fixed Voltage 14.2V
battery chargingLithium BatteryOrion DC-DC Converters not smartalternatorfloat
marvs avatar image
marvs answered ·
Yes, you should connect the charger output to the busbar thru a circuit breaker or fuse.
You need to program all of your charging parameters based on the battery manufacturers recommendations/direction.
