Steve avatar image
Steve asked
VRM False alarm
I have a shunt configure as DC load, I have an "High voltage alarm" reported by VRM that's keep coming even after I cleared it.
Cerbo GX firmware v3.20
The alarm is not configured to be active
The voltage on this shunt is normal, 13.58V as indicated in the photo below ( not above the high voltage threshold )
Where this alarm comes from and how I get rid of it ?
Thank you
cerbo gxVRMSmartShuntalarm
Alexandra avatar image
Alexandra answered ·
@Steve
Check on the shunt itself if the auxiliary is configured for anything.
Steve avatar image Steve commented ·
Hi @Alexandra, thank you for your suggestion, you solved my problem. It was not the auxiliary but the high voltage alarm clear value on the device itself that was too low, 13V, I changed it for 14.5V
