Neo Nos avatar image
Neo Nos asked
Victron 12-200 BMS before or after Lynx Distributor and Shunt?
What is the best order of setup between the BMS Smart 12-200 & Smart Shunt... I am also using a Lynx Distributor. I am a bit confused whether the solar MPPT should also be connected to the System+ terminal of the BMS 12-200? (I am sorry I am a novice vanlifer and I just spent all my savings on Victron so I can restore power to my van, any help will be gladly appreciated)
My setup consists of the following if it matters:
3x200AH VE Lithium 12v
Smart BMS 12-200
Smart Shunt
Lynx Distributor
Cerbo GX
Orion-TR
Multiplus 2 3000W
2 x MPPT Chargers (100-30 100-50)
Unfortunately all the examples I find online consist of using the LynxBMS or the other BMS systems.
Thank you so much community.
BMSSmartShuntlynx distributor
