Scott Derrick avatar image
Scott Derrick asked
Switching the Orion DC to DC charger
I would like to control an Orion DC to DC charger with the auto's battery voltage. I'm charging a 24v battery with a 12v auto system.
I want to turn on the charger when the auto battery voltage gets above 13v, thus indicating a running engine and a near fully charged battery. I don't see a recommended product anywhere on Victron's site?
I was thinking of using a mosfet switch like this https://www.amazon.com/NOYITO-Electronic-Control-Isolation-Controlled/dp/B07D1W566D/ref=sr_1_1?keywords=voltage+controlled+switch&qid=1703869502&sr=8-1
Anybody used a similar type switch with success? Anything I need to look out for?
thanks,
Scott
battery chargingorion dc-dcswitch
Scott Derrick avatar image Scott Derrick commented ·
I just found the engine run signal under the drivers seat. I will use a relay to send that signal to the ORION. Much better than detecting a voltage change.
Victron DC to DC Converters Product Range
__________
VictronConnect VE.Bus charging manual
