andrew-keane avatar image
andrew-keane asked
Cerbo GX-S Relay "Temperature Control Rules" screen blank
After installing the GX-S, I updated the firmware to v3.12 and rebooted. I was attempting to set the two relays to function on temperature to control two 12v/50watt battery heater mats. I can select temperature as a choice for relay control through the Gx touch 50, but the “temperature control rules” page is blank for both relays 1 and 2. DVCC is enabled, and the STS temperature from a lynx smart shunt was auto-selected by the unit. It is reading correctly. I am able to toggle the relays manually. Ever seen this issue? Thanks!
cerbo gxRelaytemperature
