Chris avatar image
Chris asked
Multi with Color Controller - Generator stopping before hitting set SOC condition
Generator run on SOC condition - outside of quiet hours stopping before hitting set SOC.
SOC set to start at 25% - and stop at 60%
It is starting on 25% - but stopping on 38% (this is the relay state of the CCGx - so its that that is shutting off the generator.)
Battery voltage charge condition is disabled. Overload, Temperature and total load run are enabled
Quiet hours - seems to work as expected between programmed thresholds 15% and 30%
Battery SOC has been up to 100% using solar alone.
So..... why is the CCGx stopping charging so prematurely.?
CCGX FW - 3.12 - Multi FW - 506
MultiPlus Quattro Inverter ChargerCCGX Color ControlSOCgenerator auto start
